Greg's RV-9A Builder Site
Date: 1-2-2009
Number of Hours: 3.00
Brief Description: Strobe wiring
Messed around with the fuel filter mount, and think I have it figured out. Then I moved on to various things, including the roll servo wiring, just taking a look and figuring out what I had to do. I figured out that I need to wire from the panel to the servo, so out came the wire from the conduit that I previously installed. It has a large d pin connector that won't fit through any of the smaller bushings I installed in the spar or seat ribs. Then I decided to seperate the strobe wire in the right wing, because the right wing tip is where I'll have my VOR antenna, and Stein says to keep those apart. So, I drilled small holes in each right wing rib, and put a zip tie in there, and then used another zip tie connected to that to hold the strobe wire. The other wing tip just has the marker beacon antenna, so I just put the strobe wire in the conduit. I need to finish up the fuel ines before I proceed with the wiring, and I'm still waiting for Bonaco to provide me some parts. Namely, the O rings for the fuel pump. I also installed the transponder antenna finally.
Xponder antenna
