Trimmed the forward windscreen (is there an aft one?) to fit and then clamped and drilled to the roll bar. Then I deburred the holes, and countersunk for 6-32nd screws. I enlarged the holes in the roll bar to 7/64ths and will tap for 6/32nds screws tomorrow. Then I started in on the side skirts. I can see that I will need to trim the sides of the canopy again, just a little in order to make the side skirt thing work right. I also see why they asked for a bit of clearance on the anchor blocks. I'll have to figure something out there, since I didn't provide the specified clearance. A note I did not see...
