Fabricated the fuel pump section cover. Fastened everything with platenuts so it's all removable for maintanance and access to the fuel pumps and filters. Put a hole in each side to hang an adel clamp to hold the wires running through the center section clear of the pumps and off the floor, in case of a fuel leak the fuel wont be in contact with any wires. I still have to make a drain hole in the aft section, so that any fuel leaks go out the bottom of the cockpit, vs. filling it up like a bath tub.
