Got the rudder cable covers installed where the cables exit the fuselage. Then I installed both static ports. Next, I installed both sets of headset ports, on the aft bulkhead that supports the armrests, above them. Finally, I started on the elevator push tube. I got it cut to length, and I primed the inside of it. Then I put the hardware on each end, and drilled one end. Then I drove Jack to swimming practice.
