Got the forward two #10 screws and nuts into the gear mounts. Torque sealed everything. Then I put the brake elbows on to the gear mount holes in the bottom of the fuselage. Then, I riveted a platenut that wasn't very secure, on the center cover in the baggage compartment. I crimped the end of the phone line in the ELT compartment. I had to cut the head off the other day, to re route that line from where I eventually put the power fat wire. I bought some electrical tools at home depot the other day, and that crimper was one of them. Worked great.
