Cut the hinge pieces for the seat floors to length, measured, drilled and installed them onto the aft seat floor. I only put two positions in, vs. the 3 called for in the plans. I like to sit very reclined, and don't see the need for the upright most position. If that doesn't work, I can always go back and pop rivet in a third position. I'll save a little weight this way. Next, I pop riveted in the aft floor section. Having the hydraulic/pneumatic pop riveter really comes in handy here. A bunch of rivets to pull. Then I dimpled the holes for platenuts around the center section, countersunk some platenuts and started putting them in. Went back during Izzy's nap and riveted in the rest of the platenuts on the floor, including the ones on the aft baggage bulkhead on the floor.
