Brief Description: 695 and 757 Gussets, seat belt anchors, bellcrank
Fabricated, installed and drilled the 695 gusset which goes on the longeron and firewall, and the 757 gusset, which goes under the side rail and over the 704 bulkhead. Deburred and cleaned up the edges for priming tomorrow. Drilled seat belt anchors to the longerons, and cleaned up for priming. Drilled bellcrank, and yep, cleaned up for priming.
