Greg's RV-9A Builder Site
Date: 10-12-2007
Number of Hours: 4.00
Brief Description: Deburring and Dimpling...
Continuing on... I deburred the remainder of the left forward skin, and all of the right forward skin, and dimpled all the holes in both. Taking a break from that, I riveted some items together, like the spacer, angle and gear attach webs, and the platenuts on some of the ribs and gussets that needed to be done before final assembly. Also drilled a few holes that I had missed, it's obvious when I try to dimple and the die won't fit in the hole. It was a quick, yet tedious, 4 hours. But, my punch list is getting shorter. Deburr and countersink the longerons (lots of holes there), and deburr and dimple the center bottom skin attach points to the forward and aft skins, and a few more small things, and I'll be ready to reassemble.
