Started taking apart the fuselage so I can prep the parts for final riveting. First, took off the rudder center support bracket and trimmed it down, and cut some lightening holes in it. Then I started in on the rest. Deburring holes and edges, and countersinking as many parts as I could get too. Using the fly cutter to cut the lightening holes and holes in the gear support web took a lot of time, I changed out the blade and that helped a little. I'll continue working on parts prep over the next few sessions.
