Removed the rudder pedal assembly, and started working on attaching the brake pedals on the pilot side. Put one extra rivet in where the angles attach to the rudder pedal assembly. Drilled out the rivet, drilled to AN-3 size. Cleco'd it in, and marked the oppposite side. This is after clamping the assembly to the bench, and clamping a piece of angle to the right side pedals to keep them aligned. Did both pedals, and attached brake actuators to the assembly. Found the hardware, and put it on permanantly. Just have a few cotter pins to install, and they'll be on there. Still have to drill the mounting holes in the longeron and center support brace.
