Greg's RV-9A Builder Site
Date: 8-11-2007
Number of Hours: 4.00
Brief Description: Center Fuselage section
Started out by fabricating the 916C spacers. Modified the seat ribs as required. Got a little confused with the inboard most ribs, where I had to cut out a piece of the rib, and attach the 716B seat rib access plate. I looked at the drawings and it still showed a platenut where the access plate gets attached. I had trimmed the rib, and discarded the trimed section, but I found them in the trash and saw where they get reattached to the access plate and allow for a platenut. Trimmed ribs where bushings go, and deburred the edges of the ribs, and drilled 5/8 holes for the bushings. Installed platenuts on the seat ribs, 3 per except the outboard 915 ribs, which don't get any. Deburred edges of baggage compartment ribs, and cut the holes for the steps in both 725 baggage ribs and deburred those holes. Cleco'd in baggage ribs, and started to cleco entire assembly together, when I saw a couple places where the seatbelt anchors will need to be trimmed before I can get a good fit for match drilling. Fun stuff.
