Riveted left flap together. The top skin to the spar was easy, the top skin to the ribs was easy, but the bottom skin to the spar was tough. My hand is almost too big and I had to buck with one or two fingers holding the bar. Did I mention how great tungsten is? Anyway, used the pop rivets on the bottom side, and the trailing most hole in each rib to skin. I'll have to order some more of those buggers, they are real nice for tight spots. Sure beats trying to get in there with a crow bar and pounding the crap out of the flap. Anyway, trailing edge was last and used the standard trailing edge M.O. Came out straight as can be, probably my straightest trailing edge yet.
