Primed left leading edge skin, ribs, splice strip and platenuts. Riveted in platenuts to splice strip, then cleco'd in splice strip to the skin. Then cleco'd in all the ribs. Riveted inboard most rib first, by removing the second rib for easier access to buck after squeezing the first three rivets most aft on each rib, bottom and top. Then bucked the rest. Looks good. Next will be countersinking all the holes on the left main spar, riveting in main ribs to spar that are under the tank skin, and then attaching left leading edge and finally the left tank. Then it will be on to the wing skins.
