Mixed up a batch of proseal and touched up any potential trouble spots inside the tanks. Once I rivet on the baffle, it will be too late to get back inside and fill holes. Also cut and flared the other vent lines, and fuel return lines. Drilled holes for the anti rotation brackets. Bent fuel return line for the left tank to go around the float sender. Used a smaller diameter tube for a model, and then match bent the final line to it. Then installed and cut to fit the vent line for the left tank. That was easier to bend, so I just put it in, bent it to get it out of the way of the float, and then cut for a perfect fit.
