Riveted on the platenuts to the reinforcement ring and rib on both tanks. Drilled Fuel Cap flange. I got the deluxe caps without the locks, they look great. Countersunk the rivet holes in the fuel cap flanges. Fabricated the clips that hold the vent line that are attached to the fuel cap flanges. Also, drilled the fuel drain flanges. I used a matching bolt to hold the flange in place, centered on the hole, when I drilled the flange. Started deburring all the holes, starting with the #8 screw holes on the end of the fuel tanks that attach to the main wing spar. Finished 3/4's of those holes when Izzy started calling for me after her nap.
