Greg's RV-9A Builder Site
Date: 1-13-2010
Number of Hours: 7.00
Brief Description: Wings
Tried the new software upgrade. The upgrade worked, but the buttons still didn't. Suspect a loose wire inside the box. Called Advanced and they are overnighting me another unit. Have to remove this one tomorrow, and install the new one, and set it up for everything. This is a pain, but Advanced's customer service is excellent. The great news of the day is that I put fuel in each tank and there were no leaks. I left the fuel in all day, and will check it in the morning to make sure, but at least there were no gushing leaks. Maybe a seap tomorrow, but seaps are acceptable, leaks are not. I also put the ailerons in place for good, and just have to adust the center pushrod to find the neutral position of both ailerons. The easiest way will be to put the tips on, because I lined them up on those, using the aileron alignment tool. Then I'll connect the sticks to the ailerons, and then the flaps. Hopefully, all tomorrow. Also going to check the fuel pump, and see if any of my fuel connections have any leaks. Possibly also run the engine for the first time. We'll see. I also need to remove the faulty EFIS though, so I'm behind my schedule for finishing by the end of the week, probably won't be done until Tuesday, if I work through the weekend. My inspection is going to be Wednesday or Thursday, so I'm going to hit it to get it done.
wings on for good
