Got the rest of the bolts for the wings installed and torqued. Then installed the tank attach bolts, and the rear spar bolts. Still have to safety wire the tank attach bolts, and put a cotter pin in the rear spar bolts. Then started on the empenage fairing. Drilled the holes for the platenuts and the longeon holes that will get tapped for #6 screws. Finally, tried to fire up the 4500 and the buttons didn't work. Called Advanced and they told me to download the latest software and reinstall that tomorrow. Will try it, but I bet I end up returning this unit.
