Greg's RV-9A Builder Site
Date:  5-18-2009
Number of Hours:  6.50
Brief Description:  EGT, CHT sensor wiring
Crimped and soldered on the connectors for the EGT and CHT sensor wires. Screwed up a couple of the female connectors, when solder got inside them, and wouldn't allow the male to enter. Have to be careful not to let the solder get in there... Got those done, and then spent a few minutes tidying up the right side wires and securing them to the engine mount. Then I ran the pitot heat wire through the conduit, and cut a small hole in the conduit and pulled it through near the pitot. Then I crimped that wire to the pitot heat controller. Then I ran some coax through the left wing for the VOR antenna, and removed the shielded wire for the strobe from the right wing, where I had attached it to the lightening holes with zip ties, which I didn't like. I think it will be better to run the strobe wire through the condit, with the nav lights, and marker beacon antenna coax. I will run the auto pilot servo shielded wire seperate, through the holes in the ribs, with grommets installed. I actually had just the right amount of grommets and I put those in, waiting for the 4 conductor shielded wire from Steins. Then I crimped on the molex connectors for the strobes at the end of each wing. I think that's it for the day.
