Greg's RV-9A Builder Site
Date: 1-1-2009
Number of Hours: 3.00
Brief Description: fuel lines
Re-installed the flexible fuel line on the right side. I had previously tried once again to fabricate the fuel line out of hard line, but decided to go back to the flexible line from Bonaco. Also, installed all the soft grommets on the various braces for the fuel lines, both supply and return. Also installed the screws that hold the ports on the fuel valve, all 24 of them. Then I tightened the fittings for the fuel valve, and tightened the supply and return hoses. Then I installed the fuel valve. Then I started forward on the fuel line, from the valve to the filter and on to the pump. I installed the firewall passthroughs for the supply and return lines, and measured for the flexible lines between the filter and pump, and the pump and the firewall. Before measuring, I fabricated the short 90 degree line from the valve to the filter. Next I'll mount the filter in preparation of receiving the short flexible lines and o ring adapters for the filter, and I'll install the overflow line from the pump to the overflow hole in the bottom of the plane.
Firewall fittings for fuel supply and return
