Greg's RV-9A Builder Site
Date:  4-27-2008
Number of Hours:  4.00
Brief Description:  Canopy Frame
Cut the forward post that hold the rollers down by about 1/2 inch to get the forward bow down some. Then fit the roller tracks and got the side of the canopy to fit the side of the fuselage. Drilled the rear track into place, and drilled and fit the 1/4 threaded rod that holds the forward part of the rear track in place (and will be a nice coat hanger someday) Drilled the holes for the tracks into the fuselage. All other frame members pretty much fit perfectly. I was amazed and will double check it again before drilling the canopy. Last, I marked the centerline on the bubble, and started cutting around the edges of the canopy with the dremel and cutting disk. It's messy, and slow going but I don't think it will be too tough. Just have to go slow and mind that disc. That could cut a finger in a split second.
