Installed left wing aileron bellcrank. Fabricated both aileron bellcrank pushrods, primed the inside of them by spraying primer through them and rolling them around. Then I drilled and riveted the ends on them, and smoothed out the rivets so that they won't catch or bind on anything near the aileron pushrod exit hole in the wing near the aileron attach point. Finally, I attached them to each bellcrank. Cleaned up the shop and measured to make sure entire plane with both wings on will fit. It will, just barely.
