Brief Description: Joining Center and Rear Fuselage
Prepped and primed center section side plates, and the side seat ribs. Bolted in the side seat ribs through the rear bulkhead. Cleco'd in the rest, because I'm not sure I should rivet those in yet. Prepared the rear fuselage for mating with the center fuse, (I removed some cleco's), and positioned both pieces. They went together without any problem. I read on some other sites not to cleco in the baggage skins until after the two were together, and thats what I did. I also did it right side up, and will install the longerons right side up probably, unless I think of a good reason not to. Then I'll flip the whole thing over and continue. Installed the longerons for the first time to figure out exactly where I need to notch them. Did that and marked them for notching.
