Finished up Left elevator riveting. Fabricated ribs for the trim tab, bent the ends down (had a little trouble there), match drilled, deburred and countersunk. Placed the trim tab half of the hinge and match drilled that. Riveted in the trim spar to the lower side of the skin, pro-sealed the trim tab ribs, and both elevator trailing edges and secured the trailing edges to my aluminum angle pieces to keep them straight. I'll let them sit until next weekend and then I'll back rivet. There was a lot more to the trim tab than I expected, but I wanted to get all the pro sealing done today so I could finish the tail section before the wing kit arrives. I have a few more things to finish up this week with the trim tab, and the shop needs a good cleaning.
