Riveted in reinforcement plates and platenuts to the spar. Riveted in 904 rib, and the associated parts. Riveted in the counterbalance rib, and the weight was attached. Some of those rivets in the counterbalance rib were tough to buck, because of the tight space, but with a variety of bucking bars and some patience, they were done. Started to cleco in the skin, but the stiffener upper edge was interfereing with the reinforcement plate, so I had to grind down the stiffener a bit to get a better fit. Ready to go now.
