GOTTFRIED'S WEB SITE
Date:  3-27-2020
Number of Hours:  3.00
Brief Description:  Radio harness, antenna installation
Installed the plugs for the radio headset into the seat pan where I can easily hook t up when sitting in the ship.
Installed the antenna on the mount. Drilled the 4 needed holes and made sure the antenna base is solidely connected to the frame ground. I measured the required antenna coax cable length and got one ordered.
Installing head phone connectors
temporary PTT switch to check ratio function
Antenna installation
