GOTTFRIED'S WEB SITE
Date:  5-28-2019
Number of Hours:  3.00
Brief Description:  instrument labeling
It isn required to have all instruments labeled to indicate limits.
Here I started to attach the green-yellow-red ranges to the face of the engine and transmission pressure and temperature gauges. Pretty dedious work with tiny pieces of colored tape, but turned out good and looks like factory installed.
Thegauges have to be taken apart and then the bezel has to be riveted back onto the housing. Made these rivets myself on my lathe.
Temp/Press/ limit color tape installed
color limitations on engine temp-press gaugeG
