I bought a set of Avioliites, which cover all FAA requirements for position and strobbe lights. After determining the mounting position on the sides of the cabin shells, where they can be seen from all required angles, it was time to hook them up electrically. I installed a small 4 pin connector to each of the light. This allows me to unhook the lights from the harness, when I need to remove the cabin shells from the Helicycle for inspection and maintanance.
