Finally received my engine speed sensor. It needsto be sealed at the tip so theengine oil doesnot leak through the sensor. The proposed methode is to seal the tip of the sensor with JB Weld. I turned the sensor on the lathe and removed the the ensulation material to the defined depth and then mixed JB Weld and put it on the tip and let it cure.
