I wanted all wiring which are flight critical (Gov1, Gov1, MFS Rotor/engine rpa ,...) wired directly without a connector from the panel to the actuator. For all other wiring to none critical items I will use a D-sub connector to make removal of the panel easier. I fabricated a connector mount out of an aluminum channel, which is held in place by the two push button switches for the start and start fuel buttons.
