made the pitot tibe today. Cut the provided sheet metal into theround shape, drilled the needed hole in a 60 degree angle and soldered the copper tube onto the plate. Then I installed it, lined it up and drilled the mounting holes according the drawing. Then I installed 3 nut plates.
