Brief Description: Installation of right side half door
Drilled the 5 holes to hold the right cabin door in place. Drilled the holes a bit too close to the edge of the door frame and the nuts would not sit flush. I made some doublers and expxied them on the inside of the door frame so the nuts would be supported properly. If I would have moved the holes closer to the inside of the track, I probably would have gotten away without adding doublers. It just added an hour to the job. So be it.
