Drilled 2 more holes in the front of the cabin halveson each side and clecoed the halves to the seat pan. Did another alignment check and then started drilling the holes to cleco the halves together. Started on front bottom and worked my way up the back of the cabin. Spacing between holes is about 3.5".
