Before i will make the 3 brazes for the tail fin assembly, it should be afjusted close to the final setting. The setting of the verticle and horizontal fin will impact the angles and length of the braces. Using my lazer levels capability to beam a vertical plane accross the verticle fin tip to a point 16" to the right of the rotor boom. My verticle fin needed to be turned quite a bit to the right and I had to cut off about 3/8" of the tube for the rear mounting of the fin. My verticle fin is now set to the 15" -17" offset as defined in the Eagle R&D drawing.
