Brief Description: Tail fin assembly, spar drilling
Marked spas location on upper and lower fin and drilled holes into spar. They all hit perfectly in the middle of the spar.Also marked location for braces, which should no interfer with rivets. These braces will be installed later
Doublers installed
Checking spar location with straight piece of wood
