GOTTFRIED'S WEB SITE
Date:  3-21-2016
Number of Hours:  5.00
Brief Description:  cabin winshield installation
Did some more shaping and sanding of the windshield. Cut off about1/8" at the front to make to fit well.Laid out the hole pattern on the cabin to drill the mounting holes for the windshield .Windshield will be held in place by 41 screws.
After everything looked goodand fit well I had no excuses anymore and started drilling the holes into screen very carefully.Started drilling in the back of the windshield and worked my way forward skipping every other hole. Once everything looked good I finished drilling all remaining holes, chamfered them and smoothened out all corners.
checking fit and marking where to cut off more material
starting in the back and working my way forward
Last holeto be drilled
