Brief Description: Fitting of the retension bolts for the blade gripp
Finally received the retension bolts for the blade grips.The bolts are a couple of thousands of an inch too big and needed to be lapped to fit. I used my lathe to carefully take the cad plating off the surface and then lapped the bolt into the gripps and blade. Used lots of never seize to make sure that the bolts would not seize up. I ended up with a snug fit and it takes a few taps with a mallet to install the bolts and I am happy with the fit.
