Brief Description: governor to throttle pot hook-up
Routed the last 3 wires from the potentiometer on the collective grip o the governor. Routed the shielded 3 conductor cable through the governor plate using a small rubber grommet. I made sure that the terminals of hese wires will fit through the rommet hole in case the governor ox needs o be emoved and I don't want to cut this cable to do this.
