Brief Description: Radio harness, antenna installation
Installed the plugs for the radio headset into the seat pan where I can easily hook t up when sitting in the ship. Installed the antenna on the mount. Drilled the 4 needed holes and made sure the antenna base is solidely connected to the frame ground. I measured the required antenna coax cable length and got one ordered.
