GOTTFRIED'S WEB SITE
Date:  3-17-2020
Brief Description:  Finishing bus bar panel hook-up
Installed the shunt to the bottom of the bus bar panel and also hooked up the jumper from shunt to Battery + bus bar. The battery cables are hooked up to the bottom of the bus bar panel and the voltage is fed through the /4" bolt and an isolated copper bushing o the bus bars on top of the panel.
jmper and shunt installed
