I did the fuel flow test with the fuel lift pump on and measured the time to pump 5 gal into an external tank. I did this first with the external tank on the ground and then put the external tank at the same level as the engine, which reduced the flow a bit as expected.
The fuel flow tests provided results between 22.2 and 24 gal/hr, which is higher than the min flow requirements specified by EagleR&D of 19 gal/hr.
fuel pumped into external takon ground
fuel pumped into external 5 gal tank at engine height
