Mounting the electical carness with tie wraps works, but will usually put a lot of pressure onto the harness and also allows the harness to rotate around a tube it is mounted to. I was looking foe a better solution and machinedp some aluminum mounts which could be mounted onto the frame tubes and then allow the harnes to be zip tied to it
