Had quite the time to get the oil tank from leaking when checking all 1/8" NPT connectons. The fitting at the bottom of the tank always leaked. Further investigation showed, that when tke tank halves were made, a big air bubble was allowed to stay between the fiberglass layers and the thread was cut right through this bubble. Filled the big void with BG-Weld which took care of this problem.
