Brief Description: Decals for lower instrument panel
Wanted to have the instrument panel look a little more professional than just having name tags tuck each swith and breaker. Designed the pattern on my Mac computer using "Apple Letter". Takes a bit of effort the get the size to fit the panel layout. Once the design is fixed the design is then printed on water decal paper using my inkjet printer. The water decal is then moved onto the painted instrument panel and positioned. The water is then squeezed out under the clear paper. After everthing is dry, I sprayed a clear coat of polyurethane sealer over everthing to protect the rather delicate labels. Took a few trials, but eventually I was happy with the outcome. On picture #2 , I still had to get the clutch fast/slow position corrected, but eventually, I got it right.
First shot at lower panel decals
First trial with gauge, swithes and push buttons installed
