Time to make the 3 braces for the tail feathers.Took me a while to decide, if I should just heat the tube and bend it, or if I should brace a piece of flat stock to the tubing. Decided to just heat the tube with my acetelyn torch and bend it to the correct angle.I made some paper templates to help get the angle I needed. Worked out betterl than I though. I made sure to let the 4130 tubing cool down slowly to avoid getting it hardened and brittle.
