Brief Description: Fuel line routing to engine and aux tank
Watched BJ's video on fuel line routing to engine and also looked at pictures of other builders to determine the best way to rout my fuel lines from the filter to the shut off valve and from there to the fuel control unit at the turnine. The fitting on the turbine is a AN6 fitting and I had alread purchesd a polyurethane fuel line with steel braiding. Spent always th longerst time trying to make up my mind waht's the best solution. Finally decided to rout the line from the shut off valve up under the top tank and then back down to the fuel control unit. I also had to finalize the fuel line from the aux. tank to the fuel finter. The cabin halves did not allow for routing of this line and I had to change the fuel fitting to a 45 degree fitting to get the fuel hose closer to the center of the ship and I did not want to discinnect the fuel hose from the aux. tank every time I would have to take of the right cabin shell. It'snow allconnected, does not interfere with the contols or the cabin shell. Probaly had to install and take off the shells 5 time to get it all lined up.
