The mounting holes for the 2 bearing shells are quite misaligned, when the drive shaft is aligned pre Eagle instructions. The defined 1/4" bolt would not fit without elongating these holes significantly. I can fit a smaller diameter #8 bolt through there, but have to come up with a solution. Eagle suggests just to elongate the holes. I'll hold off with this for awhile. maybe I'll come up with a better soluton.
