Started wiring of the pper panel. I will also have a D-Sub connector for all non flight critical connections, which will significantly simplify the process of removing the panel, if it should become necessary. There will be one connector for the Rotor/engine gauge, one for the radio and one for all other temp; pressure, EGT, timer, red Lion engine RPM, chip/Low fuel and low fuel pressure- and fuel level gauges.
