Switched gears and started working on my instrument panel. I rigged up a test set up for the clutch motor to validate my electical schematic. Engage; dis-engage the clutch and get a feeling for engagement speed. After this I decided that I would follow Eagle R&D's plan to have a fast and slow engagement push button. This also means that I would have to redo the lower instrument panel, since I only rilled one hole for the "fast" push botton. Here I made some trial decals for my lower panel. Seems to work quite good and I am plannng to used clear water slide paper for the decals which would go onto the panel after painting it. After the decals are attached, I plan to spray it with aclear acrylic.
