The housing for the governor provided by Eagle R&D is open on all 4 corners and the instructon says to use metal duct tape in the corners to shield the governor from radiated interference. I did not like this approach and made some corner brackets out of extruded aluminum material and expoxyied them in place withJB Weld. Then I smoothened all corners.
