The engine case is painted, so it is time to reassemble everything. Watched BJ's video on making flares on oil lines and had bought a 37 degree flaring tool, so I am all set to bending oil lines. Started out with the lines exiting the oil filter. First2 lines turned out good, but I did nt especially like the routing. Sticks out too far! Found a better way to make these oil lines. I used a piece of copper wireto easily play with the different oil line routing options without wasting the aluminum tube material provided.
